MK64 +fatfs+emmc ,save data on time(20HZ)
2,293件の閲覧回数
OneByte
I have a problem ,After storing data for a period of time(Time is not fixed), the task is suspended,Positioning is always waiting for the event completion flag position bit,SDMMC_OSAEventWait();
2,274件の閲覧回数
Pavel_Hernandez
I recommend reviewing the example in the SDK.
Pavel
3 返答(返信)
2,275件の閲覧回数
Pavel_Hernandez
Pavel
2,268件の閲覧回数
OneByte
thanks , what should I pay attention to when changing from sd storage to emmc storage? I just changed the corresponding driver file and found it was not working.
2,262件の閲覧回数
OneByte
just change fsl_sd.c->fsl_mmc.c and
fsl_sd_disk.c->fsl_mmc_disk.c
