KV5 MCGPLLCLK
KV5 MCGPLLCLK
1,076 次查看
ohiogt
The datasheet for the MKV5X has the following values in Table 17 for the PLL:
Reference Frequency Range: 8 to 16 MHz
Ipll @ 176 MHz: 2.8 mA (Note says fpll_ref = 8 MHz, VDIV = 22, 8 * 22 = 176 MHz)
Ipll @ 360 MHz: 4.7 mA (Note says fpll_ref = 8 MHz, VDIV = 45, 8 * 45 = 360 MHz)
This seems to indicate that the feedback for the PLL comes directly from the VCO output.
However, this contradicts Figure 32-1 in the reference manual.  This figure shows the feedback being derived from the fixed divide-by-2 MCGPLLCLK output.  I confirmed using the FlexBus clock output pin and the PIT that the PLL N-divider appears to actually be connected to MCGPLLCLK2X.  Can you please confirm if the following markup is correct?
标记 (3)
852 次查看
xiangjun_rong
Hi, Shawn,
If above figure is correct, the VCO output frqeuency(MCGPLLCLK2X) is 8MHz*VDIV*2, MCGPLLCLK is 8MHz*VDIV.
I will test it tomorrow, can you post the PLL setting code here?
Xiangjun Rong
852 次查看
ohiogt
Xiangjun,
Yes, I believe that's correct.  In my application I have a 10 MHz PLL reference frequency and would like MCGPLLCLK/MCGOUTCLK to operate at 160 MHz.  In the original Figure 32-1, it led me to believe VDIV should be set to 16.  I actually have to set it to 32, meaning the VDIV input must actually be connected directly to the VCO output (MCGPLLCLK2X).  Code is below:
// Name: InitOSC
// Description:
// Enables the external reference and sets clock dividers
// to initial low speed values for boot.
// Input parameters:
// None.
// Returned value:
// None.
// Algorithm:
// 1) Set low speed system clock dividers:
// Core clock: 1
// Bus clock: 6
// FlexBus clock: 6
// Flash clock: 6
// 2) Enable external oscillator
// 3) Set oscillator divider to 1 (40 MHz / 1 = 40 MHz) for
// the OSCERCLK output.
// Special Notes:
// None.
void initOSC(void)
uint32_t tmp32 = 0x00000000;
tmp32 = SIM->CLKDIV1;
tmp32 &= ~(SIM_CLKDIV1_OUTDIV1_MASK | SIM_CLKDIV1_OUTDIV2_MASK |
SIM_CLKDIV1_OUTDIV3_MASK | SIM_CLKDIV1_OUTDIV4_MASK);
tmp32 |= (SIM_CLKDIV1_OUTDIV1(0x01) | SIM_CLKDIV1_OUTDIV2(0x05) |
SIM_CLKDIV1_OUTDIV3(0x05) | SIM_CLKDIV1_OUTDIV4(0x05));
SIM->CLKDIV1 = tmp32;
OSC0->CR &= ~(OSC_CR_EREFSTEN_MASK | OSC_CR_SC2P_MASK | OSC_CR_SC4P_MASK |
OSC_CR_SC8P_MASK | OSC_CR_SC16P_MASK);
OSC0->CR |= OSC_CR_ERCLKEN_MASK;
OSC0->DIV &= ~(OSC_DIV_ERPS_MASK);
OSC0->DIV |= OSC_DIV_ERPS(0x0);
// Name: InitMCG
// Description:
// Initializes the clock generator module for high speed PLL operation
// based on the external reference.
// None.
// Returned value:
// None.
// Algorithm:
// 1) Zero out trim.
// 2) Set DCO for low speed range and 0 trim.
// 3) Select OSCCLK0 for MCG FLL external reference (Default C7 setting on KV5).
// 4) Disable loss of lock monitors.
// 5) Set the MCG range for very high frequency oscillator.
// 6) Set FLL clock source to external reference with divider of 1280. This
// results in 40 MHz / 1280 = 31.250 kHz for the FLL. This
// clock is based on OSCCLK.
// 7) Set MCGOUTCLK source to external reference.
// 8) Wait for status to indicate external reference for FLL.
// 9) Wait for status to indicate external reference for MCGOUTCLK.
// 10) Enable PLL and set reference divider to 4, so 40 MHz / 4 = 10 MHz.
// 11) Enable PLL as MCGOUTCLK. Set feedback divider to 32, so (32 * 10 MHz) / 2 = 160 MHz.
// 12) Wait for status to indicate PLL selected.
// 13) Wait for status to indicate PLL locked.
// 14) Select PLL output for MCGOUTCLK.
// 15) Wait for status to indicate PLL is active clock.
// Special Notes:
// None.
void initMCG(void)
MCG->C3 = 0x00;
MCG->C4 = 0x00;
MCG->C8 &= ~(MCG_C8_LOLRE_MASK);
MCG->C2 = MCG_C2_RANGE(2U);
MCG->C1 = (MCG_C1_CLKS(2U) | MCG_C1_FRDIV(6U));
while ((MCG->S & MCG_S_IREFST_MASK) != 0x00)
while ((MCG->S & MCG_S_CLKST_MASK) != 0x08)
MCG->C5 = (MCG_C5_PLLCLKEN0_MASK | MCG_C5_PRDIV0(3U));
MCG->C6 = (MCG_C6_PLLS_MASK | MCG_C6_VDIV0(16U));
while ((MCG->S & MCG_S_PLLST_MASK) != 0x20)
while ((MCG->S & MCG_S_LOCK0_MASK) != 0x40)
MCG->C1 &= ~(MCG_C1_CLKS_MASK);
while ((MCG->S & MCG_S_CLKST_MASK) != 0x0C)
void initRUN(void)
SMC->PMPROT &= ~(SMC_PMPROT_AHSRUN_MASK | SMC_PMPROT_AVLP_MASK | SMC_PMPROT_AVLLS_MASK);
SMC->PMCTRL &= ~(SMC_PMCTRL_RUNM_MASK);
while ((SMC->PMSTAT & SMC_PMSTAT_PMSTAT_MASK) != 0x01)
tmp32 |= (SIM_CLKDIV1_OUTDIV1(0x00) | SIM_CLKDIV1_OUTDIV2(0x01) |
SIM_CLKDIV1_OUTDIV3(0x07) | SIM_CLKDIV1_OUTDIV4(0x07));
852 次查看
xiangjun_rong
Hi, Shawn,
Okay, i see, the /2 divider is not in the feedback loop as the figure.
Xiangjun Rong
