KM34P144M75SF0 16-bit resolution Conversion error
jun1
Contributor V
Hello.
"KM34P144M75SF0 Data Sheet: Technical Data Rev. 2, May 2015-3.4.1.2 16-bit ADC electrical characteristics"
The above data sheet does not mention the 16-bit conversion error of the ADC, but is it the same as 12-bit?
Thank you.
DanielRuvalcaba
Unfortunately we don’t have that information for the 16-bit mode. I’m sorry for the inconvenience this may cause.
Regards, Daniel.
jun1
Contributor V
Thank you for your answer. Does that mean that 16-bit mode isn't used much?
DanielRuvalcaba
I’m sorry for the inconvenience this might cause to you but the only information we have about this is that the information is not available.
Best regards, Daniel.
