Is there any limitation for CPU frequency executing code from flash vs VDD?
For example: Is maximum speed possible at 1.7V?
10x.
Solved! Go to Solution.
Hi Mehmet Fide,
No, there is no limitation for CPU freq across the VDD range, but only the power mode has the limitation on clock freq, please kindly refer to the following for details.
B.R
Kan
Hi Mehmet Fide,
B.R
Kan
