Enable ETM on FRDM K64F using openocd
858件の閲覧回数
seemakumar
Hello  All,
How can I enable ETM and hence ETB too using openocd on Kf64f? I have the latest version of openocd 10.0.
Seema
タグ(3)
820件の閲覧回数
jingpan
Hi Seema,
FRDM-K64F has onboard openSDA. You needn't use openocd. If you use MCUxpresso for example, press Ctrl+3, then type trace, select “instruction trace”. The instruction trace window will appear.
Jing
