I have run the coverity for KW36 SDK and I have found 555 issues.
Please find the attached coverity report.
Let us know when these issues can be fixed?
Thanks!
Naven Suresh
Hi XingChang,
The Coverity has been run already and the report is shared.
Is the Coverity results run by you are matching with our report?
If necessary, Can you run the Coverity with high aggressive level and check?
Naven Suresh
Hi Naven,
Could you please tell me, which project did you run Coverity on? I have run on ble_shell freertos and I only obtain ~270 total defects, while in the excel file there are ~550. And also could you please tell me how you have configured the analysis? (a screenshot of the Analysis Options pop-up window would be helpful)
