CAN BUS
CAN BUS
3,504 次查看
carrielbr
Someone has an example of how to use the CAN BUS in mk20dx256vll10?
Thank you
标记 (4)
1,543 次查看
Jorge_Gonzalez
Hello Caio Carriel:
I would recommend you to download the KSDK platform: Software Development Kit for Kinetis MCUs|Freescale
Once installed you will find CAN examples. The examples are for the TWR-K60D100M, but you can create a new K20 project as indicated in the next document. Just select the K20 device in the New Project Wizard:
Writing my first KSDK1.2 Application in KDS3.0 - Hello World and Toggle LED with GPIO Interrupt
Then copy the source files and code from the CAN example.
Besides of KSDK, then depending on your software platform (CodeWarrior, KDS, IAR, with/without Processor Expert) there are some other examples available:
- In our webpage: K20_100 |Kinetis 20 100 MHz MCUs|Freescale  (Kinetis 100 MHz Rev 2 Example projects)
- Other posts by searching in this community:
CAN driver code example for Kinetis K60
CAN interface of K60/K40 controller using Processor Expert
CAN example coding for kinetis
CAN_LDD usage
Kinetis K60 CAN Configuration
Most examples are for K60_100 MHz, but the module is the same in your K20_100 MHz device, so you can copy the code in a new project, or for the Processor Expert projects you can copy the components to a new K20 project and replicate the source files, like next tutorials by colleague Erich Styger:
Copy of Processor Expert Components | MCU on Eclipse
Export and Import Processor Expert Component Settings | MCU on Eclipse
Regards!
Jorge Gonzalez
