Hi everyone,
I am new with KDS and I tried to use KDS to perform firmware changes on a IoT device, Hexwear, I have encountered the error of makefile:136: recipe for target 'HEXIWEAR_MK64.elf' failed once I build the source file of the firmware from source code of the firmware.
Any method to fix?
Thank you so much!!!!
i am facing same issue. in library paths i can see Pedomenter. but still got same error
Please advice.
Raghavendra
Hello Frances,
This stack is not NXP proprietary so for more information I will suggest to contact Hexiwear for this, but the log file mention that a file wasn't found, the path that mention I think the libPedometerLib.a. Maybe in the library paths (right click -> properties -> C/C++ General -> Paths and Symbols) the right path for the library isn't added.
Alexis Andalon
