debugger closes - reports mis-aligned memory read in log
1,204件の閲覧回数
mike1974
My application is crashing and the debugger closes, so I can't see what happened.  The debugger reports a "mis-aligned read" just before shutting down.
I"m attaching the log, it's quite long but only the last few lines (just before it shuts down) are interesting.
Anyone seen this before? Or know what could cause it?
--Mike
Original Attachment has been moved to: gdb_log.zip
1,085件の閲覧回数
Carlos_Mendoza
Hi Michael,
Could you tell us which MCU and KDS version are you using?
Regarding the error, does this happen while executing a specific instruction? Can you post your project so we can test it on our side?
Thanks!
Carlos Mendoza
Technical Support Engineer
