What files for version control?
929 次查看
davepfaltzgraff
Senior Contributor I
I am using KSD with PE and MQX. As I understand it, the MQX functionality is covered by libraries outside of my code. Also, some of the code in my project is generated by PE. So, what is the minimum set of files that I need to submit to version control? (Note: It's also a means of backup and recovery.)
742 次查看
BlackNight
The article Version Control with Processor Expert Projects | MCU on Eclipse is for CodeWarrior, but it applies 98% for Kinetis Design Studio too.
Erich
743 次查看
BlackNight
Erich
742 次查看
davepfaltzgraff
Hi Erich,
That should give me enough to go on
Thanks.
