Can it be used as Testing tool for Black box testing where we are not making changes in code ?
735 次查看
vaibhav_bait999
I work in automotive domain. We want to use freeMaster as testing tool for black box testing. Where inputs and outputs are
Inputs    : Hardwired pin signals to controller , CAN or LIN signals
Outputs : Hardwired pin signals to controller , CAN or LIN signals
We also want fault insertion scenarios as well. Where
1. we will send one input
2. Based on output , we will insert fault at specified time and watch another input.
How freeMaster can be used in these cases ?
Is there any other devices or tools needed along with freeMaster ?
679 次查看
iulian_stan
Hi vaibhav.bait999@gmail.com‌,
Let me first clarify the scope of the FreeMASTER tool, to check whether it fits your use-case: FreeMASTER's base functionality consists of monitoring and controlling embedded application variables by manipulating target memory, it does not go as low as simulating hardware inputs/outputs (for this one you'd use a dedicated software such as CAN analyzer).
  • Can FreeMASTER monitor inputs/outputs ?
    •   Yes, in case the embedded application stores those values in dedicated variables. Also, the embedded application should continuously update those values (read inputs, write outputs).
  • Can FreeMASTER be used without code modifications ?
    • The only options that does not require code changes is to use a debug probe BDM/JTAG that grants direct access to target memory. In all other options (CAN/LIN/UART) you'd need to embed FreeMASTER driver (library) into the embedded application in order to enable the communication.
Hope this helps,
Iulian
