Need help with Interrupts on MCF51QE128 (DEMOQE128)
1,553件の閲覧回数
BobbyMK
I'm new to MCUs. I'd like to know if anyone can tell me where I can find a good tutorial on how to use the interrupts on the MCF51QE128.
Thanks for any help you can give me
Bobby
1,013件の閲覧回数
Takao
Are you using CodeWarrior? If so, there are example projects in C that you could try to follow to learn how to use interrupts. There is an example project specifically for the DEMOQE128 which toggles the LED and buzzer.
