Hi Adrain,
I configured the SDRAM in code warrior script and set the SDRAM address as download algorithm address. With is configuration, i performed the 256MB of DDR3 memory test. it was working fine and faster also when compare with DDR3 set as download algorithm.
Thanks for your information.
Karunakaran R
