pragma CODE_SEG of __EntryPoint function Issue
1,199 次查看
amit_dhand
I have created a demo project in Code Warrior 10.6 with Processor Expert for S12ZVC micro controller.
Function __EntryPoint is the initialisation function for the project which is defined as
INIT _EntryPoint  in the Linker Command File.
In file CPU.c function __EntryPoint is defined under
#pragma CODE_SEG __NEAR_SEG NON_BANKED
But map file shows this function lies in
OBJECT-ALLOCATION SECTION
     Name               Module                 Addr   hSize   dSize     Ref    Section   RLIB
MODULE:                 -- Cpu_c.obj --
- PROCEDURES:
     _EntryPoint                             FD0003      59      89       1   .init
Now I created another function Cpu_Test_func in CPU.c under the same segment #pragma CODE_SEG __NEAR_SEG NON_BANKED in which __EntryPoint function is placed.
Then map file shows Cpu_Test_func lies in
- PROCEDURES:
          Cpu_Test_func                       FD005C      33      51       1   .init
My Observations are
1) Function created in the file where the init function is defined and also under same segment then the function goes into .init segment.
2) Function created in different file where the init function is not defined and also under same segment then the function goes into the correct segment.
Now my question is why this happens like that. Is it a bug of CodeWarrior 10.6 for S12ZVC. How can I resolve them.
Amit Dhand
819 次查看
trytohelp
Hi all,
This is may be linked to the Thread:
    Problem with S12ZVC startup code
Pascal
Freescale Technical Support
820 次查看
trytohelp
Hi all,
Pascal
819 次查看
ZhangJennie
please upload your demo code including Cpu_Test_func() functions.
please also mention the CW version: Start the IDE and click on Help | About CodeWarrior Development Studio. Send me the version and build id.
thanks!
Zhang Jun
819 次查看
amit_dhand
Hello Jennie,
thank you for your support.
I am using CodeWarrior for MCU S12ZVC
    Version: 10.6
    Build Id:140329
Thank you
Amit Dhand
