MISRA C 2004 General Exceptions for HCS12
10,476 次查看
arunkumarg
I am working on HCS12 microcontroller, need to understand the MISRA C 2004 general exceptions for the same.
Please share the document for reference of general exceptions .
Thanks in advance ....
10 回复数
10,061 次查看
ZhangJennie
please see attached. If this is what you need.
Jennie Zhang
10,061 次查看
vigneshbalaji
Senior Contributor I
Is there any Similar exceptions for KEA-128 regarding MISRA 2004. Please share with me some Documents regarding that.
10,061 次查看
ZhangJennie
Attach is MISRA_C_2004 Compliance Exceptions.pdf for CW10.x.
Kinetis is included.
Jennie Zhang
10,060 次查看
arunkumarg
Thank you for your mail.
I have MISRA C 2004 violations for Rule No: 12.13 and 17.4. Please clarify me whether those 2 violations are exceptions and safe?
Best Regards
ArunKumar
10,060 次查看
ZhangJennie
If your following question is regarding to KDS, I would suggest your question to KDS space. This space is for  CodeWarrior only.
https://community.nxp.com/community/mcuxpresso/kinetis-design-studio
you will get help. Thanks for your understanding.
Jennie Zhang
10,057 次查看
arunkumarg
This is regarding code warrior.
Please clarify whether MISRA C 2004 Rule 12.13 and 17.4 are under general exception and safe.
Thanks in advance.
Best Regards
Arunkumar
10,057 次查看
ZhangJennie
For CW, No, these two are not under the rule.
Jennie Zhang
10,057 次查看
arunkumarg
Hi ,
Thank you for your mail,
I am looking for some document where any other deviation apart from Rule 12.13 and 17.4 are documented as exceptions and they are safe .
Thanks in advance.
Best Regards
ArunKumar
10,057 次查看
ZhangJennie
You are welcome ArunKumar.
10,057 次查看
vigneshbalaji
Can you give me a similar document for KDS in which kinetis exceptions are mentioned?
