Hi.
GB60 is ARCHIVED product which is no longer for new design recommendation.
both classic CW6.3 and eclipse CW10.7 can support GB60. but please note:
- CW6.3 doesn't support 64bit win7 platform but 10.7 does.
- because GB60 is very old product, nearly all the existing demo codes are based on CW6.3 but not CW10.7.
here is the link of CW6.3
CodeWarrior for Microcontrollers-Classic IDE|NXP
here is the link of CW10.7
CodeWarrior for Microcontrollers-Eclipse IDE|NXP
here is demo code of GB60 demo board
GB60 modules demo code is attached.
Jennie Zhang
Thanks Jennie and Alice,
The M68DEMO908GB60.zip sample code is in assembly language. I am looking for the sample code in C language.
Appreciate if you could point to the link with the sample code in C language.
HI Dang,
unfortunately we don't have the same C demo code M68DEMO908GB60.zip
However I found we have
http://cache.nxp.com/files/microcontrollers/doc/user_guide/HCS08QRUG.pdf
GB60 modules demo code is attached. I suggest you look it though, this will help you better understand HCS08 peripheral usage.
Best Regards.
Jennie
Hi.
Jennie Zhang
Hello Jennie
The <https://community.nxp.com/servlet/JiveServlet/download/2028-438392-849405-395441/M68DEMO908GB60.zip> M68DEMO908GB60.zip sample code is in assembly language. I am looking for the sample code in C language.
Hello minh,
You can use the lasted version of CWv10.7:
it supports this chip.
In CW , create one project with Processor Expert , there will be demo :
when create project select "Processor Expert":
For example the AsynchroSerial demo :
Hope it helps
Alice
