Hello everyone,
I have an issue since I've migrated from Codewarior 10.2 to 10.3 (for Coldfire).
I get a compiler error on most of my projects. The error is as below:
'Invoking: ColdFire Compiler'
"D:/WinApps/CW MCU v10.3/MCU/ColdFire_Tools/Command_Line_Tools/mwccmcf" @@"src/app_menu.args" -o "src/app_menu_c.obj" "../src/app_menu.c" -MD -gccdep
### D:/WinApps/CW MCU v10.3/MCU/ColdFire_Tools/Command_Line_Tools/mwccmcf Usage Error:
# Argument(s) expected
# while parsing option '-i'
Attached are the makefiles generated by codewarior
After investigating, it seems that include path which contains the character '-' on one directory gives this error (in my example, D:/LDL/SW/BBSW/CCM/adc/tag/491000010031-adc/src).
I don't have this error on Codewarior 10.2, Is there any way to avoid this issue in 10.3 without renamming all include folders ?
Benjamin
Original Attachment has been moved to: app_menu.args.zip
Original Attachment has been moved to: makefile.local.zip
Original Attachment has been moved to: subdir.mk.zip
已解决! 转到解答。
Benjamin - did you get an answer to this or come up with a workaround? I am having the same problem. The presence of a dash ( - ) in the path will cause this error. CW 10.2 was fine with a dash, but CW 10.3 isn't.
-Kevin
-Kevin
