RAM overlap : Bootloader & user program
508 次查看
rubykrishna
Hi All,
We have two different projects i.e Bootloader and user program . Consider the following sequence on power on reset,  .
bootloader startup code ->bootcode->user program start up code->userprogram
Can we use  different global variables(global variable 1 : Boot loader & global variable : 2 user program ) which share the same RAM location.
Anyhow, im clearing RAM (start up code ). while jumping to application. there  shouldn't be any issues right?
Can we used shared RAM  in this case ? Is there any implication ? please help ?
381 次查看
trytohelp
Hi Ruby,
It's very important for us to know the software and hardware configuration you're using.
1- Software: what is the tool version used ?
To do that you must:
  Under CodeWarrior IDE (classic)
                Start the IDE and click on Help | About Freescale CodeWarrior.
                Click on Installed Products
                Provide us all info displayed.
                Or you can save them in a txt file.
  Under Eclipse IDE
    1-        Start Eclipse and click on Help ¦ Freescale Licenses
                The Status column gives the status of the license.
                Under Product, select it and click on details.
                A new dialog show up giving license details.
    2-        Start Eclipse and click on Help ¦ About CodeWarrior Development Studio
                Under Installed Products, you will see the version used.
2- Hardware:
    1- Device/processor/board
    2- Interface (Multilink, etc ...).
Pascal
Freescale Technical Support
