Re-Hosting failed
Re-Hosting failed
2,149 次查看
SVC2
I am trying to re-host the floating license on a new computer without success.
I opened a service request but it is not even assigned after a week...So much for a fast serivce.
On the new computer.
1)    I re-installed CodeWarrior
2)    Got the new license from your website (re-hosting) and overwritten the old license.dat
3)    Installed FlexLM
Still cannot run Codewarrior as I get the following error.
No valid license key was found for this installation of CodeWarrior Development Studio.
Please register your product by following the instructions on the
registration card or by contacting [email protected].
The desired vendor daemon is down
1) Check the lmgrd log file, or 2) Try lmreread
Feature: Win32_CWIDE_Limited
Vendor:Host: simon10
License path: C:\Program Files\Freescale\CodeWarrior for ColdFire V7.1 - \license.dat
FLEXlm error: -97,121
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".
Any clue will be appricated.
S
1,086 次查看
CrasyCat
Specialist III
Hello
You are getting FLEXlm error #-97. According to FLEXlm Reference manual this means:
  "The desired vendor daemon is down.lmgrd log file, or
   1) Check the
   2) Try lmreread."
Did you check what is written to the log file after a failing attempt to start the IDE?
Did you try to stop the service on the server and restart it?
CrasyCat
