CW 10.1 Unable to enable GCC extensions
1,230 次查看
Focon
When i try to enable GCC extensions in the compiler, I get the following error when compiling:
C:/Program Files/Freescale/CW MCU v10.1/MCU/ARM_Tools/Command_Line_Tools/mwccarm|Usage|Error
>Unknown option 'gcc'
Does anyone know how solve this? Or is it a known issue?
regards.
831 次查看
stanish
Hi Focon,
This is a known issue.
To enable gcc extensions type "-gccext on" into ARM Compiler -> Language -> "Other Flags" edit box. (see attached screenshot)
Stanish
831 次查看
Focon
Is there an admin which could move this subject to CodeWarrior - General discussion forum.
I guess i posted this question in the wrong forum section.
Thank you.
831 次查看
JWW
Moved from Kinetis to CodeWarrior group
-JWW
