__COUNTER__ macro not recognized in Power Architecture 8.8 build 80229
853 次查看
Lennie
I'm starting with codewarrior and trying to port my library to it but the compiler doesn't recognize the __COUNTER__ predefined macro although it is supposed to exist in the CodeWarrior Build Tools Reference for Power Architecture PDF.
I get :
Error : undefined identifier '__COUNTER__'
Does anyone know why ? Is it a version specific macro ?
Thanks.
671 次查看
CrasyCat
Specialist III
Hello
Which revision of the Power Arch Build Tools Reference.pdf are you referring to here.
I checked the manual with revision date of October 07, 2008, which is delivered with V8.8 and there is no mention of
predefined macro __COUNTER__ in there.
I did perform some additional tests and the predefined macro __COUNTER__ has been added in CodeWarrior Development Studio for Power Architecture v8.8.3 patch.
So if you want to use that macro, I would recommend you to install the latest patch for CodeWarrior V8.8.
According to our web page
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-POWER-NETWORKING&fpsp=1&tab=Design...
 it is
         CodeWarrior for Power Architecture v8.8.5 Patch (Windows)
I hope this helps.
CrasyCat
