Compiler Listings
Compiler Listings
1,276件の閲覧回数
bobw
For the life of me, I cannot get the compiler to generate listings for HCS08 and CFV1 using CW 10.0.
Anyone?
4 返答(返信)
613件の閲覧回数
CrasyCat
Specialist III
Hello
There are 2 ways of achieving that:
   1- If you want to check assembly code for a selected number of files:
        - Open the source file in an edit window
        - Click right inside of the edit window and select Disassemble. A new edit window is opened showing disassembly listing for selected file.
   2- If you want to check assembly code for a all files within the project:
       - Open the project Propertied dialog
       - Go to theC/C++ Build -> Settings page
       - Go to HCS08 Compiler -> General panel
       - Add option -Lasm to the Other flags edit box
       - Click on OK to save the changes
       - Rebuild the application. You should see the generated .lst files in your build directory.
CrasyCat
613件の閲覧回数
bobw
That worked for the HCS08. Thanks. Now how about for Coldfire?
613件の閲覧回数
CrasyCat
Specialist III
Hello
For Coldfire
       - Go to ColdFire-> Language Settings panel
       - Add option -S to the Other flags edit box
       - Rebuild the application. You should see the generated .s files in your build directory.
I have notified the doc team that this needs to be better documented.
CrasyCat
613件の閲覧回数
bobw
Thanks CC.
What's confusing is that, in the Output options folder directly above the General folder, there is the following option:
"Generate Listing File (e.g. %n.lst)(-Lasm)" This lead me to believe the option should be set here.... -Lasm=%n.lst
This really needs some clarification, since compiler listings are OUTPUT options, not GENERAL options.
