i.MX Yocto Project: What Can I Do if I Run Into a Compilation Error?
1. When reusing the build directory, sometimes compilation errors are seen; to overcome these, a fast solution is to clean the Share State Cache of the particular recipe/package
$ bitbake <name of the recipe> -c cleansstate
2. Re-run the recipe
3. Re-run the bitbake command you were running, before getting into trouble. For example:
$ bitbake fsl-image-gui
In case the problem persists, please send the log into the mailing list or check if this issue has been reported previously.
Comments
Hello
I have bad luck and I run into a compilation error. The error comes at xserver compilation. How can I know the exact <name of the recipe> for that recipe?
Usually when there is an error, the message is in red and it contains the name of the recipe/package. Can you post your log? What image are you building?
Leo
Hello and thanks Leo
I think I can remember a cuestion about coloring test during installation process. I fear I have difficulty with some obscure letters and I answered 'No colors'. Do you think I can get back the cuestion?
Testing and looking deeper I find that the directory containing the tmp\log.do_compile* files seems to be the recipe name: xserver-xorg-2_1.11.2-r11, in this case. But I did the cleanstate option and not get solved the problem. So I also wrote to the mailing list with the error.
I can not find how to attach the log with the errors. These are the lines where the error comes:
arm-poky-linux-gnueabi-libtool: compile:  arm-poky-linux-gnueabi-gcc -march=armv7-a -mthumb-interwork -mfloat-abi=softfp -mfpu=neon -mtune=cortex-a9 --sysroot=/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite -std=gnu99 -DHAVE_CONFIG_H -I. -I../include -I../hw/xfree86/os-support -I../hw/xfree86/os-support/bus -I../hw/xfree86/common -I../hw/xfree86/dri -I../mi -I../hw/xfree86/dri2 -DHAVE_DIX_CONFIG_H -Wall -Wpointer-arith -Wmissing-declarations -Wformat=2 -Wstrict-prototypes -Wmissing-prototypes -Wnested-externs -Wbad-function-cast -Wold-style-definition -Wdeclaration-after-statement -Wunused -Wuninitialized -Wshadow -Wcast-qual -Wmissing-noreturn -Wmissing-format-attribute -Wredundant-decls -Werror=implicit -Werror=nonnull -Werror=init-self -Werror=main -Werror=missing-braces -Werror=sequence-point -Werror=return-type -Werror=trigraphs -Werror=array-bounds -Werror=write-strings -Werror=address -Werror=int-to-pointer-cast -Werror=pointer-to-int-cast -fno-strict-aliasing -D_BSD_SOURCE -DHAS_FCHOWN -DHAS_STICKY_DIR_BIT -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/pixman-1 -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/freetype2 -I../include -I../include -I../Xext -I../composite -I../damageext -I../xfixes -I../Xi -I../mi -I../miext/sync -I../miext/shadow -I../miext/damage -I../render -I../randr -I../fb -fvisibility=hidden -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/libdrm -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/libdrm -I/home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/X11/dri -DGLX_USE_TLS -DPTHREADS -O2 -pipe -g -feliminate-unused-debug-types -c glxscreens.c  -fPIC -DPIC -o .libs/glxscreens.o
In file included from ../include/privates.h:145:0,
                 from ../include/pixmapstr.h:53,
                 from ../include/windowstr.h:52,
                 from glxscreens.c:37:
../include/dix.h:532:22: warning: redundant redeclaration of 'ffs' [-Wredundant-decls]
In file included from ../include/dixstruct.h:28:0,
                 from glxserver.h:42,
                 from glxdricommon.c:38:
                 from ../include/cursor.h:54,
                 from ../include/scrnintstr.h:54,
                 from glxdriswrast.c:42:
../include/dix.h:532:22: warning: redundant redeclaration of 'ffs' [-Wredundant-decls]In file included from ../include/privates.h:145:0,
                 from glxdri.c:40:
                 from glxcmds.c:38:
                 from glxdri2.c:39:
glxdricommon.c: In function 'createModeFromConfig':
glxdricommon.c:141:32: error: 'GLX_RGBA_BIT' undeclared (first use in this function)
glxdricommon.c:141:32: note: each undeclared identifier is reported only once for each function it appears in
glxdricommon.c:143:32: error: 'GLX_COLOR_INDEX_BIT' undeclared (first use in this function)
glxdricommon.c:147:33: error: 'GLX_NON_CONFORMANT_CONFIG' undeclared (first use in this function)
glxdricommon.c:149:33: error: 'GLX_SLOW_CONFIG' undeclared (first use in this function)
glxdricommon.c:151:33: error: 'GLX_NONE' undeclared (first use in this function)
glxdricommon.c:156:42: error: 'GLX_TEXTURE_1D_BIT_EXT' undeclared (first use in this function)
glxdricommon.c:158:42: error: 'GLX_TEXTURE_2D_BIT_EXT' undeclared (first use in this function)
glxdricommon.c:160:42: error: 'GLX_TEXTURE_RECTANGLE_BIT_EXT' undeclared (first use in this function)
Thanks again and best regards
if the '-c cleansstate xserver-xorg' did not help, I think the next step is to remove the whole tmp folder (yes, it hurts :smileyhappy:) . Regarding the colour question, somewhere on the setup this question is done, and I do not know who to change this setting.
Again, what image are you building? if this issue happening on dylan branches?
Hello Leonardo
Sorry. I forgot to answer your second question. danny is the branch we are compiling. We got a succesful compilation on a virtual machine but when we do, apparently, the same thing in a real linux, it failed.
Hello
I felt very sad about having to delete tmp directory. So I renamed it to tmp_no instead of deleting it. Then do the bitabke fsl-image-gui. The build process give us this warnings:
WARNING: The recipe is trying to install files into a shared area when those files already exist. Those files are:
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/glx.h
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/glext.h
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/glu.h
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/gl.h
   /home/dgg/rootfs_buider/build/tmp/sysroots/imx6qsabrelite/usr/include/GL/glxtokens.h
and end the buiild process correctly ... and soon :smileyshocked: .
After it, I understand that rename is not the same that delete. The process must be using yet the tmp_no directory and has been able to do something in the new directory. I am going to delete now the tmp_no directory and see what happens.
Hi Diego,
AFAIK, Danny branches are not updated anymore. In case you want the most update & stable branch, use Dylan branches (there must be a way to jump from branchs A to branches B using the repo command. In case there is no way, you need to 'repo -init -b dylan' again)
Leo
Thanks Leonardo
As a matter of fact, danny is not working on imx6 q sabre lite.  We write on another post saying that the compiled image has errors on start and they said to us that we must use dylan. We create a new directory and it will end compiling in a few miuntes ... I hope :smileyhappy:
08/13 dylan working. thanks
%3CLINGO-SUB%20id%3D%22lingo-sub-1106724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%20Yocto%20Project%3A%20What%20Can%20I%20Do%20if%20I%20Run%20Into%20a%20Compilation%20Error%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.%20When%20reusing%20the%20%3CA%20href%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2F1.3%2Fdev-manual%2Fdev-manual.html%23build-directory%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ebuild%3C%2FA%3E%20directory%2C%20sometimes%20compilation%20errors%20are%20seen%3B%20to%20overcome%20these%2C%20a%20fast%20solution%20is%20to%20clean%20the%20%3CA%20href%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fpoky-ref-manual%2Fpoky-ref-manual.html%23shared-state-cache%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EShare%20State%20Cache%3C%2FA%3E%20of%20the%20particular%20recipe%2Fpackage%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20%3CNAME%20of%3D%22%22%20the%3D%22%22%20recipe%3D%22%22%3E%20-c%20cleansstate%3C%2FNAME%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20Re-run%20the%20recipe%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20%3CNAME%20of%3D%22%22%20the%3D%22%22%20recipe%3D%22%22%3E%3C%2FNAME%3E%3C%2FP%3E%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20Re-run%20the%20%3CEM%3Ebitbake%3C%2FEM%3E%20command%20you%20were%20running%2C%20before%20getting%20into%20trouble.%20For%20example%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20fsl-image-gui%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20case%20the%20problem%20persists%2C%20please%20send%20the%20log%20into%20the%20%3CA%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emailing%20list%3C%2FA%3E%20or%20check%20if%20this%20issue%20has%20been%20%3CA%20href%3D%22https%3A%2F%2Fbugzilla.yoctoproject.org%2Fbuglist.cgi%3Fproduct%3DBSPs%26amp%3Bcomponent%3Dbsps-meta-fsl-arm%26amp%3Bresolution%3D---%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ereported%3C%2FA%3E%20previously.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1106724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20What%20Can%20I%20Do%20if%20I%20Run%20Into%20a%20Compilation%20Error%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20Leonardo%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAs%20a%20matter%20of%20fact%2C%20danny%20is%20not%20working%20on%20imx6%20q%20sabre%20lite.%26nbsp%3B%20We%20write%20on%20another%20post%20saying%20that%20the%20compiled%20image%20has%20errors%20on%20start%20and%20they%20said%20to%20us%20that%20we%20must%20use%20dylan.%20We%20create%20a%20new%20directory%20and%20it%20will%20end%20compiling%20in%20a%20few%20miuntes%20...%20I%20hope%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20again%26nbsp%3B%20and%20best%20regards%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E08%2F13%20dylan%20working.%20thanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20What%20Can%20I%20Do%20if%20I%20Run%20Into%20a%20Compilation%20Error%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Diego%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAFAIK%2C%20Danny%20branches%20are%20not%20updated%20anymore.%20In%20case%20you%20want%20the%20most%20update%20%26amp%3B%20stable%20branch%2C%20use%20Dylan%20branches%20(there%20must%20be%20a%20way%20to%20jump%20from%20branchs%20A%20to%20branches%20B%20using%20the%20repo%20command.%20In%20case%20there%20is%20no%20way%2C%20you%20need%20to%20'repo%20-init%20-b%20dylan'%20again)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20What%20Can%20I%20Do%20if%20I%20Run%20Into%20a%20Compilation%20Error%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20felt%20very%20sad%20about%20having%20to%20delete%20tmp%20directory.%20So%20I%20renamed%20it%20to%20tmp_no%20instead%20of%20deleting%20it.%20Then%20do%20the%20bitabke%20fsl-image-gui.%20The%20build%20process%20give%20us%20this%20warnings%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWARNING%3A%20The%20recipe%20is%20trying%20to%20install%20files%20into%20a%20shared%20area%20when%20those%20files%20already%20exist.%20Those%20files%20are%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fglx.h%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fglext.h%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fglu.h%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fgl.h%3C%2FP%3E%3CP%3EWARNING%3A%20The%20recipe%20is%20trying%20to%20install%20files%20into%20a%20shared%20area%20when%20those%20files%20already%20exist.%20Those%20files%20are%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FGL%2Fglxtokens.h%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eand%20end%20the%20buiild%20process%20correctly%20...%20and%20soon%20%3Asmileyshocked%3A%20.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAfter%20it%2C%20I%20understand%20that%20rename%20is%20not%20the%20same%20that%20delete.%20The%20process%20must%20be%20using%20yet%20the%20tmp_no%20directory%20and%20has%20been%20able%20to%20do%20something%20in%20the%20new%20directory.%20I%20am%20going%20to%20delete%20now%20the%20tmp_no%20directory%20and%20see%20what%20happens.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20What%20Can%20I%20Do%20if%20I%20Run%20Into%20a%20Compilation%20Error%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Leonardo%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESorry.%20I%20forgot%20to%20answer%20your%20second%20question.%20danny%20is%20the%20branch%20we%20are%20compiling.%20We%20got%20a%20succesful%20compilation%20on%20a%20virtual%20machine%20but%20when%20we%20do%2C%20apparently%2C%20the%20same%20thing%20in%20a%20real%20linux%2C%20it%20failed.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20What%20Can%20I%20Do%20if%20I%20Run%20Into%20a%20Compilation%20Error%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eif%20the%20'-c%20cleansstate%20xserver-xorg'%20did%20not%20help%2C%20I%20think%20the%20next%20step%20is%20to%20remove%20the%20whole%20tmp%20folder%20(yes%2C%20it%20hurts%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E)%20.%20Regarding%20the%20colour%20question%2C%20somewhere%20on%20the%20setup%20this%20question%20is%20done%2C%20and%20I%20do%20not%20know%20who%20to%20change%20this%20setting.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAgain%2C%20what%20image%20are%20you%20building%3F%20if%20this%20issue%20happening%20on%20dylan%20branches%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20What%20Can%20I%20Do%20if%20I%20Run%20Into%20a%20Compilation%20Error%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20and%20thanks%20Leo%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20think%20I%20can%20remember%20a%20cuestion%20about%20coloring%20test%20during%20installation%20process.%20I%20fear%20I%20have%20difficulty%20with%20some%20obscure%20letters%20and%20I%20answered%20'No%20colors'.%20Do%20you%20think%20I%20can%20get%20back%20the%20cuestion%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETesting%20and%20looking%20deeper%20I%20find%20that%20the%20directory%20containing%20the%20tmp%5Clog.do_compile*%20files%20seems%20to%20be%20the%20recipe%20name%3A%20xserver-xorg-2_1.11.2-r11%2C%20in%20this%20case.%20But%20I%20did%20the%20cleanstate%20option%20and%20not%20get%20solved%20the%20problem.%20So%20I%20also%20wrote%20to%20the%20mailing%20list%20with%20the%20error.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20can%20not%20find%20how%20to%20attach%20the%20log%20with%20the%20errors.%20These%20are%20the%20lines%20where%20the%20error%20comes%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Earm-poky-linux-gnueabi-libtool%3A%20compile%3A%26nbsp%3B%20arm-poky-linux-gnueabi-gcc%20-march%3Darmv7-a%20-mthumb-interwork%20-mfloat-abi%3Dsoftfp%20-mfpu%3Dneon%20-mtune%3Dcortex-a9%20--sysroot%3D%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%20-std%3Dgnu99%20-DHAVE_CONFIG_H%20-I.%20-I..%2Finclude%20-I..%2Fhw%2Fxfree86%2Fos-support%20-I..%2Fhw%2Fxfree86%2Fos-support%2Fbus%20-I..%2Fhw%2Fxfree86%2Fcommon%20-I..%2Fhw%2Fxfree86%2Fdri%20-I..%2Fmi%20-I..%2Fhw%2Fxfree86%2Fdri2%20-DHAVE_DIX_CONFIG_H%20-Wall%20-Wpointer-arith%20-Wmissing-declarations%20-Wformat%3D2%20-Wstrict-prototypes%20-Wmissing-prototypes%20-Wnested-externs%20-Wbad-function-cast%20-Wold-style-definition%20-Wdeclaration-after-statement%20-Wunused%20-Wuninitialized%20-Wshadow%20-Wcast-qual%20-Wmissing-noreturn%20-Wmissing-format-attribute%20-Wredundant-decls%20-Werror%3Dimplicit%20-Werror%3Dnonnull%20-Werror%3Dinit-self%20-Werror%3Dmain%20-Werror%3Dmissing-braces%20-Werror%3Dsequence-point%20-Werror%3Dreturn-type%20-Werror%3Dtrigraphs%20-Werror%3Darray-bounds%20-Werror%3Dwrite-strings%20-Werror%3Daddress%20-Werror%3Dint-to-pointer-cast%20-Werror%3Dpointer-to-int-cast%20-fno-strict-aliasing%20-D_BSD_SOURCE%20-DHAS_FCHOWN%20-DHAS_STICKY_DIR_BIT%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2Fpixman-1%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2Ffreetype2%20-I..%2Finclude%20-I..%2Finclude%20-I..%2FXext%20-I..%2Fcomposite%20-I..%2Fdamageext%20-I..%2Fxfixes%20-I..%2FXi%20-I..%2Fmi%20-I..%2Fmiext%2Fsync%20-I..%2Fmiext%2Fshadow%20-I..%2Fmiext%2Fdamage%20-I..%2Frender%20-I..%2Frandr%20-I..%2Ffb%20-fvisibility%3Dhidden%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2Flibdrm%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2Flibdrm%20-I%2Fhome%2Fdgg%2Frootfs_buider%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabrelite%2Fusr%2Finclude%2FX11%2Fdri%20-DGLX_USE_TLS%20-DPTHREADS%20-O2%20-pipe%20-g%20-feliminate-unused-debug-types%20-c%20glxscreens.c%26nbsp%3B%20-fPIC%20-DPIC%20-o%20.libs%2Fglxscreens.o%3C%2FP%3E%3CP%3EIn%20file%20included%20from%20..%2Finclude%2Fprivates.h%3A145%3A0%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20..%2Finclude%2Fpixmapstr.h%3A53%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20..%2Finclude%2Fwindowstr.h%3A52%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20glxscreens.c%3A37%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20warning%3A%20redundant%20redeclaration%20of%20'ffs'%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3EIn%20file%20included%20from%20..%2Finclude%2Fdixstruct.h%3A28%3A0%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20glxserver.h%3A42%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20glxdricommon.c%3A38%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20warning%3A%20redundant%20redeclaration%20of%20'ffs'%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3EIn%20file%20included%20from%20..%2Finclude%2Fprivates.h%3A145%3A0%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20..%2Finclude%2Fcursor.h%3A54%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20..%2Finclude%2Fscrnintstr.h%3A54%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20glxdriswrast.c%3A42%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20warning%3A%20redundant%20redeclaration%20of%20'ffs'%20%5B-Wredundant-decls%5DIn%20file%20included%20from%20..%2Finclude%2Fprivates.h%3A145%3A0%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20..%2Finclude%2Fpixmapstr.h%3A53%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20..%2Finclude%2Fwindowstr.h%3A52%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20glxdri.c%3A40%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20warning%3A%20redundant%20redeclaration%20of%20'ffs'%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20file%20included%20from%20..%2Finclude%2Fdixstruct.h%3A28%3A0%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20glxserver.h%3A42%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20glxcmds.c%3A38%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20warning%3A%20redundant%20redeclaration%20of%20'ffs'%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3EIn%20file%20included%20from%20..%2Finclude%2Fprivates.h%3A145%3A0%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20..%2Finclude%2Fpixmapstr.h%3A53%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20..%2Finclude%2Fwindowstr.h%3A52%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20from%20glxdri2.c%3A39%3A%3C%2FP%3E%3CP%3E..%2Finclude%2Fdix.h%3A532%3A22%3A%20warning%3A%20redundant%20redeclaration%20of%20'ffs'%20%5B-Wredundant-decls%5D%3C%2FP%3E%3CP%3Eglxdricommon.c%3A%20In%20function%20'createModeFromConfig'%3A%3C%2FP%3E%3CP%3Eglxdricommon.c%3A141%3A32%3A%20error%3A%20'GLX_RGBA_BIT'%20undeclared%20(first%20use%20in%20this%20function)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A141%3A32%3A%20note%3A%20each%20undeclared%20identifier%20is%20reported%20only%20once%20for%20each%20function%20it%20appears%20in%3C%2FP%3E%3CP%3Eglxdricommon.c%3A143%3A32%3A%20error%3A%20'GLX_COLOR_INDEX_BIT'%20undeclared%20(first%20use%20in%20this%20function)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A147%3A33%3A%20error%3A%20'GLX_NON_CONFORMANT_CONFIG'%20undeclared%20(first%20use%20in%20this%20function)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A149%3A33%3A%20error%3A%20'GLX_SLOW_CONFIG'%20undeclared%20(first%20use%20in%20this%20function)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A151%3A33%3A%20error%3A%20'GLX_NONE'%20undeclared%20(first%20use%20in%20this%20function)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A156%3A42%3A%20error%3A%20'GLX_TEXTURE_1D_BIT_EXT'%20undeclared%20(first%20use%20in%20this%20function)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A158%3A42%3A%20error%3A%20'GLX_TEXTURE_2D_BIT_EXT'%20undeclared%20(first%20use%20in%20this%20function)%3C%2FP%3E%3CP%3Eglxdricommon.c%3A160%3A42%3A%20error%3A%20'GLX_TEXTURE_RECTANGLE_BIT_EXT'%20undeclared%20(first%20use%20in%20this%20function)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20again%20and%20best%20regards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20What%20Can%20I%20Do%20if%20I%20Run%20Into%20a%20Compilation%20Error%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EUsually%20when%20there%20is%20an%20error%2C%20the%20message%20is%20in%20red%20and%20it%20contains%20the%20name%20of%20the%20recipe%2Fpackage.%20Can%20you%20post%20your%20log%3F%20What%20image%20are%20you%20building%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX%20Yocto%20Project%3A%20What%20Can%20I%20Do%20if%20I%20Run%20Into%20a%20Compilation%20Error%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20bad%20luck%20and%20I%20run%20into%20a%20compilation%20error.%20The%20error%20comes%20at%20xserver%20compilation.%20How%20can%20I%20know%20the%20exact%20%3CNAME%20of%3D%22%22%20the%3D%22%22%20recipe%3D%22%22%3E%20for%20that%20recipe%3F%3C%2FNAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎02-08-2013 09:47 AM
Updated by:
