Example MPC5676R DSPI-ext_SPI_memory-S25FL129P CW210
* Detailed Description:
* The example uses serial flash memory S25FL129P (connected to DSPI_PCS1)
* that is connected to DSPI_B module (PCS1). No Dual or Quad I/O has been used.
* SW uses polling mechanism.
* The example at first read device ID, performs bulk erase of S25FL129P and then
* programs some sample data specified in main function. Check reading is then
* performed. During that some notices are displayed on the terminal window.
* Test HW:         XPC567XKIT516 - MPC567xADAT516 Rev.D, MPC567XEVBFXMB Rev.C
* MCU:             PPC5676RDMVY1 3N23A
* Terminal:        19200-8-no parity-1 stop bit-no flow control on eSCI_A
* Fsys:            180MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          RAM, internal_FLASH
* EVB connection:  default
%3CLINGO-SUB%20id%3D%22lingo-sub-1104839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5676R%20DSPI-ext_SPI_memory-S25FL129P%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20The%20example%20uses%20serial%20flash%20memory%20S25FL129P%20(connected%20to%20DSPI_PCS1)%3CBR%20%2F%3E*%20that%20is%20connected%20to%20DSPI_B%20module%20(PCS1).%20No%20Dual%20or%20Quad%20I%2FO%20has%20been%20used.%3CBR%20%2F%3E*%20SW%20uses%20polling%20mechanism.%3CBR%20%2F%3E*%20The%20example%20at%20first%20read%20device%20ID%2C%20performs%20bulk%20erase%20of%20S25FL129P%20and%20then%20%3CBR%20%2F%3E*%20programs%20some%20sample%20data%20specified%20in%20main%20function.%20Check%20reading%20is%20then%20%3CBR%20%2F%3E*%20performed.%20During%20that%20some%20notices%20are%20displayed%20on%20the%20terminal%20window.%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC567XKIT516%20-%20MPC567xADAT516%20Rev.D%2C%20MPC567XEVBFXMB%20Rev.C%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5676RDMVY1%203N23A%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20180MHz%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20EVB%20connection%3A%26nbsp%3B%20default%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1104839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20The%20example%20uses%20serial%20flash%20memory%20S25FL129P%20(connected%20to%20DSPI_PCS1)%3CBR%20%2F%3E*%20that%20is%20connected%20to%20DSPI_B%20module%20(PCS1).%20No%20Dual%20or%20Quad%20I%2FO%20has%20been%20used.%3CBR%20%2F%3E*%20SW%20uses%20polling%20mechanism.%3CBR%20%2F%3E*%20The%20example%20at%20first%20read%20device%20ID%2C%20performs%20bulk%20erase%20of%20S25FL129P%20and%20then%20%3CBR%20%2F%3E*%20programs%20some%20sample%20data%20specified%20in%20main%20function.%20Check%20reading%20is%20then%20%3CBR%20%2F%3E*%20performed.%20During%20that%20some%20notices%20are%20displayed%20on%20the%20terminal%20window.%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC567XKIT516%20-%20MPC567xADAT516%20Rev.D%2C%20MPC567XEVBFXMB%20Rev.C%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5676RDMVY1%203N23A%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20180MHz%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20EVB%20connection%3A%26nbsp%3B%20default%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎10-04-2017 05:23 AM
Updated by:
