Porting LVDS LCD With Low Resolution to i.MX6
Some customers often use LVDS LCD with low resolution on i.MX6 platform, such as 320x240, but by defualt , linux bsp doesn't support low frequency pixel clock for LVDS module input.
Question:
    When we port LVDS LCD with 320x240 resolution to android4.2.2, we found pixel clock is not correct, it always output 38.9MHz, it is no probem for big resolution , for example 1024x768, but the clock we need for 320x240 LCD is 6.4MHz.
    According to the quesiton, Let us check IPU & LDB clock in i.MX6 datasheet at first :
From above table, if ldb clock is from IPU, we will not get 6.4MHz pixel clock, so we will have to adjust its source clock:
The following steps are procedure that ports LVDS LCD with 320x240 resolution to i.MX6Q.
1. Adding LVDS LCD timing structure to ldb.c
static struct fb_videomode ldb_modedb[] = {
      "LDB-XGA", 60, 320, 240, 155914,
      38, 20,
      15, 4,
      30, 3,
      0,
      FB_VMODE_NONINTERLACED,
      FB_MODE_IS_DETAILED,
     "LDB-1080P60", 60, 1920, 1080, 7692,
     100, 40,
     30, 3,
     10, 2,
     0,
     FB_MODE_IS_DETAILED,},
2.Modifying clock source of ldb module
Checking /arch/arm/mach-mx6/clock.c, we can find there are 3 ldb's clock source : &pll5_video_main_clk, &pll2_pfd_352M, &pll2_pfd_400M,
static int _clk_ldb_di1_set_parent(struct clk *clk, struct clk *parent)
       u32 reg, mux;
       int rev = mx6q_revision();
       reg = __raw_readl(MXC_CCM_CS2CDR)
              & ~MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK;
       mux = _get_mux6(parent, &pll5_video_main_clk,
              (rev == IMX_CHIP_REVISION_1_0) ?
               &pll3_pfd_540M :       /* MX6Q TO1.0 */
               &mmdc_ch1_axi_clk[0],     /* MX6Q TO1.1 and MX6DL */
              &pll3_usb_otg_main_clk, NULL);
       reg |= (mux << MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET);
       __raw_writel(reg, MXC_CCM_CS2CDR);
       return 0;
By default, pll2_pfd_352M is configured as the clock source of ldb:
clk_set_parent(&ldb_di0_clk, &pll2_pfd_352M);
       clk_set_parent(&ldb_di1_clk, &pll2_pfd_352M);
We should change the clock source to be pll5_video_main_clk
clk_set_parent(&ldb_di0_clk, &pll5_video_main_clk,);
       clk_set_parent(&ldb_di1_clk, &pll5_video_main_clk,);
3. Configuring initial clock in board-mx6q_sabresd.c
static struct ipuv3_fb_platform_data sabresd_fb_data[] = {
       { /*fb0*/
       .disp_dev = "ldb",
       .interface_pix_fmt = IPU_PIX_FMT_RGB666,
       .mode_str = "LDB-XGA",
       .default_bpp = 16,
       .int_clk = false,
       .late_init = false,
int_clk=false means LDB clock is from PLL2_PFD_352 or pll5_video_main_clk; int_clk=true mean LDB clock if from IPU.
OK, after doing above steps, LVDS LCD with low resolution should normally work.
Freescale TICS team
Weidong.sun
2015-08-18
标签 (3)
评论
m_c
Hello Weidong,
  We use i.MX6 quad platform and our kernel verison is 3.10.53.
  We can use lvds lcd with 1024x768/65M on i.MX6 quad platform successfully, but we get problem when we change the resolution of lvds lcd to 640x240/13M.
  So, we follow your steps above and try to see whether we can get 6.4M pixel clock. The test fails.
  The below is lvds setting we use:
  1. Adding lvds lcd timing structure on arch\arm\boot\dts\lec-imx6.dtsi
lvds-channel@0 {
fsl,data-mapping = "spwg"; /* spwg or jeida */
fsl,data-width = <24>;
primary;
status = "okay";
display-timings {
native-mode = <&timing0>;
timing0: hsd100pxn1 {
clock-frequency = <6400000>;
hactive = <320>;
vactive = <240>;
hback-porch = <38>;
hfront-porch = <20>;
vback-porch = <15>;
vfront-porch = <4>;
hsync-len = <30>;
vsync-len = <3>;
  2. Modifying clock source of ldb module on arch\arm\mach-imx\clk-imx6q.c
* Kernel parameter 'ldb_di_clk_sel' is used to select parent of ldb_di_clk,
* among the following clocks.
*   'pll5_video_div'
*   'pll2_pfd0_352m'
*   'pll2_pfd2_396m'
*   'mmdc_ch1_axi'
*   'pll3_usb_otg'
* Example format: ldb_di_clk_sel=pll5_video_div
* If the kernel parameter is absent or invalid, pll2_pfd0_352m will be
* selected by default.
// modified by johnson here
static int ldb_di_sel = 0;
  3. Configuring initial clock on arch\arm\boot\dts\lec-imx6.dtsi
mxcfb3: fb@2 { /* IPU2 DI0: /dev/fb3=LVDS, fb4=IPU2's overlay
* Solo/DL: IPU1, fb2 shared with par. RGB, no overlay */
compatible = "fsl,mxc_sdc_fb";
disp_dev = "ldb";
interface_pix_fmt = "RGB666";
default_bpp = <16>;
int_clk = <0>;
late_init = <0>;
status = "okay";
  Do you have any suggestion about this problem???
  I have a LCD display with same resolution 240*320 . The kernel is 3.10.53 for Lollipop. So I am using dtsi files. We  are expecting 5.6 or 7 MHZ but always getting 24 Mhz when PLL5 clock is used instead of PLL2 . Did you able to set 6.4M pixel clock for your board?.. Other than the changes documented by Wigros  Sun , any other additional changes required for Low resolution LCD to work on I.MX6 with kernel version 3.10.53?
Thanks & Regards,
Anjali
%3CLINGO-SUB%20id%3D%22lingo-sub-1119681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B0%86%E4%BD%8E%E5%88%86%E8%BE%A8%E7%8E%87LVDS%20LCD%E7%A7%BB%E6%A4%8D%E5%88%B0i.MX6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%80%E4%BA%9B%E5%AE%A2%E6%88%B7%E7%BB%8F%E5%B8%B8%E5%9C%A8i.MX6%E5%B9%B3%E5%8F%B0%E4%B8%8A%E4%BD%BF%E7%94%A8%E4%BD%8E%E5%88%86%E8%BE%A8%E7%8E%87%E7%9A%84LVDS%20LCD%EF%BC%8C%E4%BE%8B%E5%A6%82320x240%EF%BC%8C%E4%BD%86%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8Clinux%20bsp%E4%B8%8D%E6%94%AF%E6%8C%81LVDS%E6%A8%A1%E5%9D%97%E8%BE%93%E5%85%A5%E7%9A%84%E4%BD%8E%E9%A2%91%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%E3%80%82%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSTRONG%3E%E9%97%AE%E9%A2%98%3C%2FSTRONG%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BB%AC%E5%B0%86%E5%88%86%E8%BE%A8%E7%8E%87%E4%B8%BA%20320x240%20%E7%9A%84%20LVDS%20LCD%20%E7%A7%BB%E6%A4%8D%E5%88%B0%20android4.2.2%20%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%91%E7%8E%B0%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E5%AE%83%E5%A7%8B%E7%BB%88%E8%BE%93%E5%87%BA%2038.9MHz%EF%BC%8C%E5%AF%B9%E4%BA%8E%E8%BE%83%E5%A4%A7%E7%9A%84%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%88%E4%BE%8B%E5%A6%82%201024x768%EF%BC%89%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%20320x240%20LCD%20%E6%89%80%E9%9C%80%E7%9A%84%E6%97%B6%E9%92%9F%E6%98%AF%206.4MHz%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BB%AC%E9%A6%96%E5%85%88%E6%A3%80%E6%9F%A5i.MX6%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E7%9A%84IPU%E5%92%8CLDB%E6%97%B6%E9%92%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LVDS-IMX6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LVDS-IMX6.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F52626iA072E950F26858DF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22LVDS-IMX6.png%22%20alt%3D%22LVDS-IMX6.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IPU-CLOCKpng.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IPU-CLOCKpng.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F52582iB49ED28D8FF73BF7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IPU-CLOCKpng.png%22%20alt%3D%22IPU-CLOCKpng.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%8E%E4%B8%8A%E8%A1%A8%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%87%BA%EF%BC%8C%E5%A6%82%E6%9E%9Cldb%E6%97%B6%E9%92%9F%E6%9D%A5%E8%87%AAIPU%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%976.4MHz%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E8%B0%83%E6%95%B4%E5%85%B6%E6%BA%90%E6%97%B6%E9%92%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%98%AF%E5%B0%86%E5%88%86%E8%BE%A8%E7%8E%87%E4%B8%BA%20320x240%20%E7%9A%84%20LVDS%20LCD%20%E7%A7%BB%E6%A4%8D%E5%88%B0%20i.MX6Q%20%E7%9A%84%E8%BF%87%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E1.%20%E5%9C%A8ldb.c%E4%B8%AD%E6%B7%BB%E5%8A%A0LVDS%20LCD%E6%97%B6%E5%BA%8F%E7%BB%93%E6%9E%84%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20background%3A%20white%3B%22%3E%E9%9D%99%E6%80%81%E7%BB%93%E6%9E%84%20fb_videomode%20ldb_modedb%5B%5D%20%3D%20%7B%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3E%E2%80%9CLDB-XGA%E2%80%9D%EF%BC%8C60%EF%BC%8C320%EF%BC%8C240%EF%BC%8C155914%EF%BC%8C%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3E38%2C%2020%2C%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3E15%EF%BC%8C4%EF%BC%8C%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3E30%EF%BC%8C3%EF%BC%8C%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3E0%EF%BC%8C%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3EFB_VMODE_NONINTERLACED%EF%BC%8C%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3EFB_MODE_IS_DETAILED%EF%BC%8C%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20background%3A%20white%3B%22%3E%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%7B%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E2%80%9CLDB-1080P60%E2%80%9D%EF%BC%8C60%EF%BC%8C1920%EF%BC%8C1080%EF%BC%8C7692%EF%BC%8C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20100%2C%2040%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2030%2C%203%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2010%2C%202%2C%3C%2FP%3E%3CP%3E0%EF%BC%8C%3C%2FP%3E%3CP%3EFB_VMODE_NONINTERLACED%EF%BC%8C%3C%2FP%3E%3CP%3EFB_MODE_IS_DETAILED%2C%7D%2C%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%7D%3B%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E2.%E4%BF%AE%E6%94%B9ldb%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%E6%BA%90%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E6%A3%80%E6%9F%A5%2Farch%2Farm%2Fmach-mx6%2Fclock.c%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%8F%91%E7%8E%B0%E6%9C%893%E4%B8%AAldb%E7%9A%84%E6%97%B6%E9%92%9F%E6%BA%90%EF%BC%9A%3C%2FSPAN%3E%20%3CSTRONG%3E%26amp%3Bpll5_video_main_clk%EF%BC%8C%3C%2FSTRONG%3E%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%26amp%3B%20%3CSTRONG%3Epll2_pfd_352M%EF%BC%8C%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%26amp%3B%20%3CSTRONG%3Epll2_pfd_400M%EF%BC%8C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E6%80%81int%20_clk_ldb_di1_set_parent%EF%BC%88%E7%BB%93%E6%9E%84clk%20*clk%EF%BC%8C%E7%BB%93%E6%9E%84clk%20*parent%EF%BC%89%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20reg%2C%20mux%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20int%20rev%20%3D%20mx6q_revision()%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ereg%20%3D%20__raw_readl%EF%BC%88MXC_CCM_CS2CDR%EF%BC%89%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26amp%3B%20~MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emux%20%3D%20_get_mux6%EF%BC%88%E7%88%B6%E7%BA%A7%EF%BC%8C%26amp%3Bpll5_video_main_clk%EF%BC%8C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26amp%3Bpll2_pfd_352M%2C%20%26amp%3Bpll2_pfd_400M%2C%3C%2FP%3E%3CP%3E%EF%BC%88%E7%89%88%E6%9C%AC%3D%3DIMX_CHIP_REVISION_1_0%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E%26amp%3Bpll3_pfd_540M%3A%2F*MX6Q%20TO1.0*%2F%3C%2FP%3E%3CP%3E%26amp%3Bmmdc_ch1_axi_clk%5B0%5D%2C%20%2F*%20MX6Q%20TO1.1%20%E5%92%8C%20MX6DL%20*%2F%3C%2FP%3E%3CP%3E%26amp%3Bpll3_usb_otg_main_clk%EF%BC%8C%E7%A9%BA%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3Ereg%20%7C%3D%EF%BC%88mux%26lt%3B%3CMXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET%3E%3C%2FMXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E__raw_writel%EF%BC%88%E6%B3%A8%E5%86%8C%EF%BC%8CMXC_CCM_CS2CDR%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%200%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%E9%BB%98%E8%AE%A4%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%E9%85%8D%E7%BD%AEpll2_pfd_352M%E4%BD%9C%E4%B8%BAldb%E7%9A%84%E6%97%B6%E9%92%9F%E6%BA%90%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0pt%3B%22%3Eclk_set_parent%EF%BC%88%26amp%3Bldb_di0_clk%EF%BC%8C%26amp%3Bpll2_pfd_352M%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3Eclk_set_parent%EF%BC%88%26amp%3Bldb_di1_clk%EF%BC%8C%26amp%3Bpll2_pfd_352M%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E5%B0%86%E6%97%B6%E9%92%9F%E6%BA%90%E6%9B%B4%E6%94%B9%E4%B8%BA%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3Epll5_video_main_clk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2021.0pt%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20red%3B%22%3Eclk_set_parent%EF%BC%88%26amp%3Bldb_di0_clk%EF%BC%8C%26amp%3Bpll5_video_main_clk%EF%BC%8C%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20red%3B%22%3Eclk_set_parent%EF%BC%88%26amp%3Bldb_di1_clk%EF%BC%8C%26amp%3Bpll5_video_main_clk%EF%BC%8C%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E3.%20%E5%9C%A8board-mx6q_sabresd.c%E4%B8%AD%E9%85%8D%E7%BD%AE%E5%88%9D%E5%A7%8B%E6%97%B6%E9%92%9F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E6%80%81%E7%BB%93%E6%9E%84%20ipuv3_fb_platform_data%20sabresd_fb_data%5B%5D%20%3D%20%7B%3C%2FP%3E%3CP%3E%7B%20%2F*fb0*%2F%3C%2FP%3E%3CP%3E.disp_dev%3D%E2%80%9Cldb%E2%80%9D%EF%BC%8C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.interface_pix_fmt%20%3D%20IPU_PIX_FMT_RGB666%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.mode_str%20%3D%20%22LDB-XGA%22%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.default_bpp%20%3D%2016%2C%3C%2FP%3E%3CP%3E.int_clk%3D%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%3CSTRONG%3E%E5%81%87%3C%2FSTRONG%3E%3C%2FSPAN%3E%EF%BC%8C%3C%2FP%3E%3CP%3E.late_init%3D%20%E5%81%87%EF%BC%8C%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3Eint_clk%3Dfalse%20%E8%A1%A8%E7%A4%BA%20LDB%20%E6%97%B6%E9%92%9F%E6%9D%A5%E8%87%AA%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EPLL2_PFD_352%20%E6%88%96%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3Epll5_video_main_clk%3C%2FSPAN%3E%20%EF%BC%9Bint_clk%3Dtrue%20%E8%A1%A8%E7%A4%BA%20LDB%20%E6%97%B6%E9%92%9F%E6%9D%A5%E8%87%AA%20IPU%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E5%AE%8C%E6%88%90%E4%B8%8A%E8%BF%B0%E6%AD%A5%E9%AA%A4%E5%90%8E%EF%BC%8C%E4%BD%8E%E5%88%86%E8%BE%A8%E7%8E%87%E7%9A%84LVDS%20LCD%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20TICS%20%E5%9B%A2%E9%98%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EWeidong.sun%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E2015-08-18%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1119681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%E4%BD%8E%E5%88%86%E8%BE%A8%E7%8E%87LVDS%20LCD%E7%A7%BB%E6%A4%8D%E5%88%B0i.MX6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%88%86%E8%BE%A8%E7%8E%87%E4%B8%BA%20240*320%20%E7%9A%84%20LCD%20%E6%98%BE%E7%A4%BA%E5%99%A8%E3%80%82Lollipop%20%E7%9A%84%E5%86%85%E6%A0%B8%E6%98%AF%203.10.53%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E4%BD%BF%E7%94%A8%20dtsi%20%E6%96%87%E4%BB%B6%E3%80%82%E6%88%91%E4%BB%AC%E6%9C%9F%E6%9C%9B%E7%9A%84%E6%98%AF%205.6%20%E6%88%96%207%20MHZ%EF%BC%8C%E4%BD%86%E5%BD%93%E4%BD%BF%E7%94%A8%20PLL5%20%E6%97%B6%E9%92%9F%E8%80%8C%E4%B8%8D%E6%98%AF%20PLL2%20%E6%97%B6%E6%80%BB%E6%98%AF%E5%BE%97%E5%88%B0%2024%20Mhz%E3%80%82%E6%82%A8%E8%83%BD%E4%B8%BA%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E8%AE%BE%E7%BD%AE%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E6.4M%20%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%E5%90%97%EF%BC%9F%E9%99%A4%E4%BA%86%20Wigros%20Sun%20%E8%AE%B0%E5%BD%95%E7%9A%84%E6%9B%B4%E6%94%B9%E4%B9%8B%E5%A4%96%EF%BC%8C%E8%BF%98%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E6%9B%B4%E6%94%B9%E6%89%8D%E8%83%BD%E4%BD%BF%E4%BD%8E%E5%88%86%E8%BE%A8%E7%8E%87%20LCD%20%E5%9C%A8%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%203.10.53%20%E7%9A%84%20I.MX6%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%92%8C%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%AE%89%E8%B4%BE%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%E4%BD%8E%E5%88%86%E8%BE%A8%E7%8E%87LVDS%20LCD%E7%A7%BB%E6%A4%8D%E5%88%B0i.MX6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%8D%AB%E4%B8%9C%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20i.MX6%20%E5%9B%9B%E6%A0%B8%E5%B9%B3%E5%8F%B0%EF%BC%8C%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%BA%203.10.53%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%9C%A8%20i.MX6%20%E5%9B%9B%E6%A0%B8%E5%B9%B3%E5%8F%B0%E4%B8%8A%E6%88%90%E5%8A%9F%E4%BD%BF%E7%94%A8%201024x768%2F65M%20%E7%9A%84%20lvds%20lcd%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E4%BB%AC%E5%B0%86%20lvds%20lcd%20%E7%9A%84%E5%88%86%E8%BE%A8%E7%8E%87%E6%9B%B4%E6%94%B9%E4%B8%BA%20640x240%2F13M%20%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E6%8C%89%E7%85%A7%E6%82%A8%E4%B8%8A%E9%9D%A2%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%B0%9D%E8%AF%95%E7%9C%8B%E7%9C%8B%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%BE%97%206.4M%20%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%E3%80%82%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%20lvds%20%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E1.%E5%9C%A8%20arch%5Carm%5Cboot%5Cdts%5Clec-imx6.dtsi%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%20lvds%20lcd%20%E6%97%B6%E5%BA%8F%E7%BB%93%E6%9E%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20lvds%E9%80%9A%E9%81%93%400%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20fsl%EF%BC%8C%E6%95%B0%E6%8D%AE%E6%98%A0%E5%B0%84%3D%E2%80%9Cspwg%E2%80%9D%EF%BC%9B%2F*spwg%E6%88%96jeida*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20fsl%EF%BC%8C%E6%95%B0%E6%8D%AE%E5%AE%BD%E5%BA%A6%3D%26lt%3B24%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E5%9F%BA%E6%9C%AC%E7%9A%84%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E6%98%BE%E7%A4%BA%E6%97%B6%E9%97%B4%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E6%9C%AC%E6%9C%BA%E6%A8%A1%E5%BC%8F%20%3D%20%26lt%3B%26amp%3Btiming0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E8%AE%A1%E6%97%B60%EF%BC%9Ahsd100pxn1%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%3D%26lt%3B6400000%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E6%B4%BB%E6%80%A7%3D%26lt%3B320%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E8%99%9A%E6%B4%BB%E6%80%A7%EF%BC%9D%26lt%3B240%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20h%E5%90%8E%E5%BB%8A%3D%26lt%3B38%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20hfront-porch%20%3D%20%26lt%3B20%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20v%E5%90%8E%E5%BB%8A%3D%26lt%3B15%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20vfront-porch%20%3D%20%26lt%3B4%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20hsync-len%20%3D%20%26lt%3B30%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20vsync-len%20%3D%20%26lt%3B3%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E2.%E4%BF%AE%E6%94%B9arch%5Carm%5Cmach-imx%5Cclk-imx6q.c%E4%B8%8Aldb%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%E6%BA%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%2F*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%20%E5%86%85%E6%A0%B8%E5%8F%82%E6%95%B0%E2%80%98ldb_di_clk_sel%E2%80%99%E7%94%A8%E4%BA%8E%E9%80%89%E6%8B%A9ldb_di_clk%E7%9A%84%E7%88%B6%E7%BA%A7%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%20%E5%9C%A8%E4%B8%8B%E5%88%97%E6%97%B6%E9%92%9F%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%26nbsp%3B%26nbsp%3B%20'pll5_video_div'%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%E2%80%9Cpll2_pfd0_352m%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%20'pll2_pfd2_396m'%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%26nbsp%3B%26nbsp%3B%20'mmdc_ch1_axi'%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%26nbsp%3B%26nbsp%3B%20'pll3_usb_otg'%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%20%E7%A4%BA%E4%BE%8B%E6%A0%BC%E5%BC%8F%EF%BC%9Aldb_di_clk_sel%3Dpll5_video_div%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%20%E5%A6%82%E6%9E%9C%E5%86%85%E6%A0%B8%E5%8F%82%E6%95%B0%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%88%96%E6%97%A0%E6%95%88%EF%BC%8C%E5%88%99%20pll2_pfd0_352m%20%E5%B0%86%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%20%E9%BB%98%E8%AE%A4%E9%80%89%E6%8B%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%2F%2F%20%E6%AD%A4%E5%A4%84%E7%94%B1%20johnson%20%E4%BF%AE%E6%94%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E9%9D%99%E6%80%81int%20ldb_di_sel%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E3.%E5%9C%A8%20arch%5Carm%5Cboot%5Cdts%5Clec-imx6.dtsi%20%E4%B8%8A%E9%85%8D%E7%BD%AE%E5%88%9D%E5%A7%8B%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20mxcfb3%3A%20fb%402%20%7B%20%2F*%20IPU2%20DI0%3A%20%2Fdev%2Ffb3%3DLVDS%2C%20fb4%3DIPU2's%20overlay%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20*%20Solo%2FDL%EF%BC%9AIPU1%E3%80%81fb2%20%E4%B8%8E%20par%20%E5%85%B1%E4%BA%AB%E3%80%82RGB%EF%BC%8C%E6%97%A0%E5%8F%A0%E5%8A%A0%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E5%85%BC%E5%AE%B9%3D%E2%80%9Cfsl%EF%BC%8Cmxc_sdc_fb%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20disp_dev%20%3D%E2%80%9Cldb%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E6%8E%A5%E5%8F%A3%E5%83%8F%E7%B4%A0fmt%20%3D%20%22RGB666%22%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20default_bpp%20%3D%20%26lt%3B16%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20int_clk%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20late_init%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%20%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%82%A8%E5%AF%B9%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%EF%BC%9F%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎08-17-2015 11:45 PM
更新人:
