I am working on hypervisor on imx8mq-evk platform. I send an ipi but core doesn't recevice it. Below is my code.
References:
1. https://www.nxp.com/docs/en/errata/IMX8MDQLQ_0N14W.pdf
2. irq-gic-v3.c\irqchip\drivers - linux-imx - i.MX Linux kernel
Thanks for any advice!
Hi 书意 程
for ipi usage one can look at arm community:
Intercore interrupts on a53 between EL1 and EL3 - Cortex-A / A-Profile forum - Processors - Arm Comm...
interrupt distribution on A53 processor - Cortex-A / A-Profile forum - Processors - Arm Community
Thanks for your reply. But i run the code successfully on fvp with gicv3, so i think the code is correct but not work on imx8mq-evk platform.
Hello, have you solved this problem?
