MPC57XX EAR SDK, LIN Master-Slave Example Project?
eyupozer
Is there any LINFlex LIN Master-Slave example or demo projects for S32DS, MPC57XX EAR SDK V0.8.1?
I've got an MPC574XG evaluation board with MPC5746C MCU. I want to use LIN0 and LIN1 port but there is no example configuration project for LIN Flex Master-Slave communication?
martin_kovar
I received confirmation from development team that LIN support for MPC5748G is not planned.
Sorry for any inconvenience.
Martin
bwp530
hi @martin_kovar
Do you mean that there is no lin master in SDK? I'm using the MPC5748G RTM3.0, and I don't find any lin master in components library.
eyupozer
Thanks Martin for the quick support.
李月鑫
Hello:
     I am currently planning to do the LIN function development of 5748G, but I have encountered the same problem as you. I did not find relevant samples in the SDK. How did you solve it?
Best Regards
eyupozer
I did not find any demo project, I've solved this problem without SDK.
minghu_du
Hello eyupozer,
I am also trying to configure LINFlexD to LIN mode, could you please share your code with me?
martin_kovar
unfortunately, there is no example for LINFlex in SDK available at all. I will ask SDK development team, if there is any plan to create one (but for SDK RTM 2.0.0) and I will let you know.
Martin
