i.MX8MM SDK is bad
i.MX8MM SDK is bad
davidvescovi
Contributor V
Not only will it not load into Xpresso IDE the manifest is full of errors.
This could not have been tested or they would have seen the many errors.
CarlosCasillas
Hi David,
I’m afraid that MCUXpresso IDE is not supported by MCUXpresso SDK for i.MX8MM. Just IAR and GCC are supported.
Hope this will be useful for you.
Best regards!
/Carlos
davidvescovi
Contributor V
let me get this … you don't support your own toolchain?
