How to Avoid PE to Ruin Your Code during Coding?
luchaolong
What's the best way to avoid activating Processor Expert to update the code during Project build? especially during the 'Build All'?
The manual 'Build Project' will not active the PE to regenerate the code, but just in case if anyone would click the 'Build All' thus all the user's code will be ruined.
Leo
BlackNight
you can disable code generation by component and as a project settings, see Disable my Code Generation | MCU on Eclipse
I hope this helps,
Erich
BlackNight
I hope this helps,
Erich
