hi all,
I look into the fec_main.c code and some documents, I found the fec_main.c is about Motorola MPC8xx driver, I shoud write a new file for rtl8306e, Now I confused how to write "_probe" function , Is there some sample for it?
HI igor:
Thanks for your reply, the document you provided is very useful for me , but I was too Embarrassed to say that I was very new to freesclae platform and ethernet driver, I don't know how to start following three steps,and I download rtl8306e_asicdrv files in attchement rtl8306.rar.
• Pin configuration
• Source code
I modify code in fec_main.c, but I don,t know where rtk_switch_init should be add.
• Ethernet connection configuration
So, is there some example exist that can be referenced , other related drivers are also available.
Thanks very much.
Chris
Hi Chris
please look at description of Linux drivers included in documentation packages on
Hi Chris
please refer to attached Porting Guide, first try to make
rtl8306e functional in uboot, then in linux with minimal configuration.
