Sample schematics for connecting two LPDDR2 with i.MX7D
ko-hey
Senior Contributor II
Hi all
Does someone have experience for connecting two LPDDR2 ?
My customer plan to connect two LPDDR2 with i.MX7.
When 2 GB of memory capacity is used, we plan to use 2 LPDDR2 x32 1GB RAM in parallel.
It is assumed to be used with switching by CS [1: 0].
Unfortunately, we can't find out a reference schematics.
Does someone have a reference schematic ?
If yes, please share it.
Ko-hey
Labels (3)
Yuri
  As for one LPDDR device - really we have here single package, but several devices.
Control DRAM signals DRAM_DQMx, DRAM_SDQSx, address and data lines  DRAM_ADDRESSx,
DRAM_SDBAx, DRAM_DATAx, clock DRAM_SDCLK0 are common for all DRAM devices.
DRAM_CS0,  DRAM_SDCKE0, DRAM_ODT0 select and control  one device (CS0),
DRAM_CS1,  DRAM_SDCKE1, DRAM_ODT1 - the second.
Yuri.
Yuri
You may  look at WaRP7|NXP
The following about LPDDR3 and LPDDR2 differences may be useful:
< https://www.micron.com/~/media/documents/products/technical-note/dram/lpddr3/tn_5202_lpddr3_design_l... >
Yuri
ko-hey
Hi YuriMuhin_ng
I checked a schematic but it looks only one LPDDR device…
Ko-hey
Yuri
Yuri.
ko-hey
Hi Yuri Muhin
Thank you for reply.
I understand.
Ko-hey
