Hi jan spurek
Thank you
hi
i have a custom made board based on i.mx6 with 2gb ddr
i have set 2gb configuration in u-boot
but u-boot is recognizing it 1gb only
what could be the problem
regards
sadia
Hello Saida,
you need to input your new configuration in the Script Aid spreadsheet and change the affected registers in DCD accordingly.
Jan
ok
i will try it and come back to you
thank you
regards saida
Hello Saida,
400 MHz is the maximal supported frequency for i.MX6DL.
Jan
