32Khz output on CCM_CLKO2 pin of imx7
suryapradhan
Hello
I need some info regarding generation of 32khz clk on CCM_CLKO2 of IMX7.
CCM_CLKO2 is connected to SD1_WP.
I am able to generate 24mhz but not 32khz.
Any suggestion.
Thanks & regards
Surya
Labels (2)
Carlos_Musich
Hi surya,
what error are you facing?
please take a look to this post which explains were the clock sources and dividers are. CCM_CLK02 follows same principle as SAIx_CLK_ROOT indicated here iMX7D : SAIx_CLK_ROOT minimum frequency value for SAI (Serial Audio Interface )module
Carlos
