Is there any SDK for FRDM‑K64F‑AGM01 running sensor fusion on the keil compiler without RTOS ?
Hi Frank,
Yes, there is an SDK with specifications you requested. You have to go to the MCUXpresso web page, and there you will be able to use the SDK builder.
Inside the SDK you will find a folder in the route SDK_2.2_FRDM-K64F-AGM01 >> boards >> frdmk64f_agm01 >> issdk_examples >> algorithms>>sensorfusion with the libraries and source code.
If this didn't answer your question let me know.
Darío
