Freescale sensor fusion toolbox: change commas to dots
nielsjongen
In the Freescale sensor fusion toolbox.
There is a way to record data into a csv file. The problem is the program measure values with a comma. The csv uses a comma to. So there will be a problem between them. There is a way to change the measured values to dot values.
10,5 ==> 10.5
nielsjongen
If you are in Europe you got this problem. Standart Europe uses komma's and the US uses dots. So you need to change your computers settings to english and US. => Problem fixed
