I have installed the KSDK 1.3 but I need to remove it, it does not show up in the control panel and the installer does not have an option to remove it, some guidance please
Solved! Go to Solution.
The installer for the SDK 1.3 is basically a self-extracting zip file plus it sets an environment variable. So you simply can remove the inistallation folder from your disk. Check the system environment variables, it defines something like
KSDK_1_3_0_PATH=C:\NXP\KSDK_1.3.0
ointint to where you have installed it. Remove that variable too, and this should do it.
I hope this helps,
Erich
I hope this helps,
Erich
