Hi,@ Kerry Zhou, jeremyzhou,
Please share me example code for ADC with DMA. I did not find in example code bundle.
it will be very much helpful to proceed further.
Ranjith
Could you provide the chip's part number?
There is an application note about ADC DMA application, please check here for the detailed info.
Related software could be downloaded at here.
Wish it helps.
Ma Hui
Hi @ Hui_Ma
Thanks for your reply.
I am using LPC824 chip with LPCXpresso IDE.
It will be really helpful, if you provide provide sample code for above mentioned part number.
Ranjith
Please refer attached ADC with DMA demo based on LPCXpressor54114 board, which is also suitable for LPC824 product.
Wish it helps.
Ma Hui
