Dear community:
hello, i have an ov5642 module using parallel connector ,one i.mx6qp sabre SD board and an environment running yocto project. how can i use this module on board? should i change the kernel or just type commands in board command line or write my code and cross compile it then run on the board?
Do you have a guide or some documents? sorry for the stupid question but I really donno how to continue.
thank you!
please check sect.19.2 OV5642 Using parallel interface attached Linux Manual
and useful links
https://community.nxp.com/thread/329673
https://boundarydevices.com/ov5642-auto-focus-on-i-mx6/
