Where can I find the sources of the UTP daemon, i.e. the component that talks to the MfgTool in Linux user space?
It seems that the documentation of the MfgTool is rather outdated as many commands listed there appear to be not implemented or not functional.
Chris.
Solved! Go to Solution.
Here is the daemon that runs on the target:
GitHub - NXPmicro/imx-uuc: A Daemon wait for Freescale/NXP mfgtools host's command
In case you don't have the mfgtools source code, here it is:
GitHub - NXPmicro/mfgtools: Freescale/NXP I.MX Chip image deploy tools.
Gary
Can someone confirm that imx-uuc is still the best option for generating a mfgtool compatible version of the os? Also are there any online resources for integrating with buildroot?
Thanks, David
You can use the links Gary provided:
https://github.com/NXPmicro/imx-uuc
https://github.com/NXPmicro/mfgtools
Victor
Gary
Thank you, Gary!
