Using the FXLN8372QRI with Vdd = 3.3V, will the part be damaged if the Self-Test pin is at 1.5V?
We know the ST pin is specified for logic levels to function correctly; but during the time that the pin is at 1.5V we don’t care what the accelerometer outputs are… we just don’t want to damage the device.
Solved! Go to Solution.
Hi Chris,
Yes, it is outside the specific logic input levels, but not outside the absolute max ratings, so there is no need to worry about the damage.
Tomas
Hi Chris,
Tomas
