I just spent a half hour on the website looking. Doesn't seem like it should be so hard to find.
Solved! Go to Solution.
Use Appendix A of the MPCFPE32B.pdf file or Appendix B of the MPC823UM.pdf file.
These files can be loaded using the following links:
http://cache.nxp.com/files/product/doc/MPCFPE32B.pdf?fsrch=1&sr=1&pageNum=1
http://cache.nxp.com/files/product/doc/MPC823UM.pdf?fsrch=1&sr=1&pageNum=1
Pavel Chubakov
Thanks, Pavel. The second option (Appendix B of the MPC823UM.pdf) was just what I was looking for (not so much the first).
Grant
Pavel Chubakov
Ok, I found the G2 Core Ref Manual (G2CORERM.pdf). It gives me the name and syntax. Doesn't help if I don't know what it's doing. I'm picturing a document with a page for each instruction, or a least a text description of what it does. F'rinstance:
Mnemonic: addis Name: Add Immediate Shifted Syntax: rD,rA,SIMM (from G2CORERM)
OK (I infer), it adds the immediate value (SIMM) to rA and the result goes in rD. What gets shifted? By how much?
Even if I can't find the doc I expect, it would be a great help if someone can just explain this one instruction.
But c'mon, that document has to exist, right? Thanks.
