I need an assembly language reference for the MPC8280.
1,742 次查看
gschmick
I just spent a half hour on the website looking.  Doesn't seem like it should be so hard to find.
1,659 次查看
Pavel
Use Appendix A of the MPCFPE32B.pdf file or Appendix B of the MPC823UM.pdf file.
These files can be loaded using the following links:
http://cache.nxp.com/files/product/doc/MPCFPE32B.pdf?fsrch=1&sr=1&pageNum=1
http://cache.nxp.com/files/product/doc/MPC823UM.pdf?fsrch=1&sr=1&pageNum=1
Pavel Chubakov
1,659 次查看
gschmick
Thanks, Pavel.  The second option (Appendix B of the MPC823UM.pdf) was just what I was looking for (not so much the first).
Grant
1,660 次查看
Pavel
Pavel Chubakov
1,659 次查看
gschmick
Ok, I found the G2 Core Ref Manual (G2CORERM.pdf).  It gives me the name and syntax.  Doesn't help if I don't know what it's doing.  I'm picturing a document with a page for each instruction, or a least a text description of what it does.  F'rinstance:
Mnemonic: addis    Name: Add Immediate Shifted   Syntax: rD,rA,SIMM (from G2CORERM)
OK (I infer), it adds the immediate value (SIMM) to rA and the result goes in rD.  What gets shifted?  By how much?
Even if I can't find the doc I expect, it would be a great help if someone can just explain this one instruction.
But c'mon, that document has to exist, right?    Thanks.
