But I am getting errors, stating the linkerscript is not found. Though I given the location properly, still it shows the error.
Kindly post the steps involved in defining variable at absolute ram address. Is there any way without using linkerscripts, like __at attribute in keil?
Content originally posted in LPCWare by fjrg76 on Thu Sep 06 17:17:25 MST 2012 There is a way for doing that in Flash, so it might be the same procedure in RAM:
GPIO_T * myVar= (GPIO_T *)(0xE0028000);
Where GPIO_T is a struct that holds the registers used by GPIO in the LPC2129 uC, but you can use whatever makes sense for your project.
This other snippet is used with LPCXpresso, and works great, although more obscure, 'cause a lot of #define(s) involved:
