Installing Built Drivers on Yocto Image?
PaulDeMetrotion
Senior Contributor I
I have prebuilt some drivers for a RedPine wireless device and need to put the drivers and scripts onto a Linux image. I have created the following rs9113_1.0.0.bb recipe but I get errors when trying to copy the drivers. I do not get these errors with the scripts. Any ideas what I am doing wrong??
rs9113_1.0.0.bb:
DESCRIPTION = "Install of rs9113 drivers and scripts"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COREBASE}/LICENSE;md5=4d92cd373abda3937c2bc47fbc49d690 \
                    file://${COREBASE}/meta/COPYING.MIT;md5=3da9cfbcb788c80a0384361b4de20420"
kmoddir = "/lib/modules/${KERNEL_VERSION}/kernel/drivers/net/wireless/redpine"
FILESEXTRAPATHS_prepend := "${THISDIR}:"
SRC_URI_append = " \
    file://onebox_common_gpl.ko \
    file://onebox_gpl.ko \
    file://onebox_nongpl.ko \
    file://onebox_wlan_gpl.ko \
    file://onebox_wlan_nongpl.ko \
    file://wlan.ko \
    file://wlan_wep.ko \
    file://wlan_ccmp.ko \
    file://wlan_tkip.ko \
    file://wlan_acl.ko \
    file://wlan_scan_sta.ko \
    file://wlan_xauth.ko \
    file://wlan_enable.sh \
    file://wlan_disable.sh \
do_install_append() {
    install -d ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/onebox_common_gpl.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/onebox_gpl.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/onebox_nongpl.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/onebox_wlan_gpl.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/onebox_wlan_nongpl.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/wlan.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/wlan_wep.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/wlan_ccmp.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/wlan_tkip.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/wlan_acl.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/wlan_scan_sta.ko ${D}${kmoddir}
    install -m 0755 ${WORKDIR}/wlan_xauth.ko ${D}${kmoddir}
    install -d ${D}/etc/redpine
    install -m 0755 ${WORKDIR}/wlan_enable.sh ${D}/etc/redpine
    install -m 0755 ${WORKDIR}/wlan_disable.sh ${D}/etc/redpine
FILES_${PN}_append += " \
    ${D}${kmoddir}/onebox_common_gpl.ko \
    ${D}${kmoddir}/onebox_gpl.ko \
    ${D}${kmoddir}/onebox_nongpl.ko \
    ${D}${kmoddir}/onebox_wlan_gpl.ko \
    ${D}${kmoddir}/onebox_wlan_nongpl.ko \
    ${D}${kmoddir}/wlan.ko \
    ${D}${kmoddir}/wlan_wep.ko \
    ${D}${kmoddir}/wlan_ccmp.ko \
    ${D}${kmoddir}/wlan_tkip.ko \
    ${D}${kmoddir}/wlan_acl.ko \
    ${D}${kmoddir}/wlan_scan_sta.ko \
    ${D}${kmoddir}/wlan_xauth.ko \
    ${D}/etc/redpine/wlan_enable.sh \
    ${D}/etc/redpine/wlan_disable.sh \
Build Errors:
ERROR: QA Issue: rs9113: Files/directories were installed but not shipped
  /lib
  /lib/modules
  /lib/modules/kernel
  /lib/modules/kernel/drivers
  /lib/modules/kernel/drivers/net
  /lib/modules/kernel/drivers/net/wireless
  /lib/modules/kernel/drivers/net/wireless/redpine
  /lib/modules/kernel/drivers/net/wireless/redpine/wlan.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/wlan_ccmp.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/onebox_common_gpl.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/wlan_tkip.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/wlan_wep.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/wlan_scan_sta.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/wlan_acl.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/onebox_wlan_nongpl.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/onebox_wlan_gpl.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/wlan_xauth.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/onebox_gpl.ko
  /lib/modules/kernel/drivers/net/wireless/redpine/onebox_nongpl.ko [installed-vs-shipped]
madisox
Remove the ${D} prefix in the FILES_${PN} setting - that's why the packager isn't finding those files.
madisox
gusarambula
Hello Paul DeMetrotion,
Are you still encountering this issue when installing the built drivers? The error seems odd. I think the _append suffix on the do_install, SRC_URI and FILES_${PN} may not be necessary.
In some forums I read that you may ignore the QA warning by using the following command, but it won’t fix the root cause so you may still be lead to an error.
INSANE_SKIP_${PN} = "installed-vs-shipped "
