It is my first exprience in the compilation of the kernel - Custom kernel.
The Compilation is completed, but the system is always working on the old one.
i have tried the Commands after (make) -> make install -> make modules_install.
thanks for the help,
Mohamad
Hi Mohamad,
I guess you just need to reburn your memory or replace the old kernel,
Please check this document Install Ubuntu 14.04 on i.MX7D-SDB
Senction 4 explain howto build new kernel and deploy it to be burn on your SDcard on section 5.
