License generation quantity exceeded
d_li
135478_135478.png2016-02-02 10_03_56-Software & Support _ Generate Licenses.png
I should be able to generate a license, but the system is not letting me. Thanks,
-David
TomasPaez
Hi ,
System was reviewed and fixed to avoid this error message. Let us know if you see any detail related to this case.
Thank you.
trytohelp
Hi David,
The problem has been solved.
I was able to generate the license file.
Pascal
NXP Technical Support
trytohelp
Hi David,
I met the problem last week and reported it to the license team.
Please can you submit your case into the new system, please follow below steps:
  1) Go to http://www.nxp.com/support/sales-and-support:SUPPORTHOME.
  2) On the bottom of the page under Submit New Issues, click Hardware & Software.
  3) Register with your business email to access NXP technical online support.
  4) A verification email will be sent to your account. Click the link embedded in that email to verify your access.
  5) On the NXP online support page, select Contact Support from the top menu and click “submit a new case” to start the process.
Pascal
TomasPaez
Hi ,
Thank you.
