Hi All,
Can anyone tell which switch needs to be changed in t2080rdb board for choosing the vxworks bootrom bank????
Solved! Go to Solution.
NOR Flash bank addresses are changed by SW3[5:7] DIP switch. These settings affect the boot process only if NOR is selected to be
the boot ROM by SW3[4]. See T2080RDBUG Table 2-9 and notes below it.
Note, no VxWorks images are pre-programmed to any T2080RDB Flash/bank. Consult at Wind River for correct
image preparation, programming and booting.
Platon
Platon
