Hello, there is a method or the possibility to use the functionalities provided by OpenSSL library for cryptographic applications development in the world of i.MX. I read about cryptographic acceleration in the CAAM but I have not found an available documentation for this. Thanks a lot!
Solved! Go to Solution.
The CAAM drivers are accelerated through the CryptoDev interface,
so customers can use OpenSSL library (with hardware acceleration)
as much as the lib supports the CryptoDev interface.
Yuri
Yuri
