I know there a lot of discussions related to VPU for imx6 on the forum but it seems none answers my question entirely as I don't have past experience with video processing.
I have a task to estimate the effort of enabling VPU support for imx6 processors. I saw the VPU application guide from Freescale
and identified the API for VPU there.
In the kernel tree it seems that VPU and IPU are used interchangeabily. Is VPU the same as IPU and GPU ?
Also , I saw on the forum that a specific SDK needs to be used in order to develop code for VPU.
But first of all I would like to know if enabling IPU support in kernel means the same thing as enabling VPU ?
Thank you,
Mihaita
Hi Mihaita
IPU and VPU are different and independent modules and
can not be used interchangeabily, enabling IPU support in kernel does not
mean the same thing as enabling VPU. More details can be found in
presentations on links below
IPU
A Deep Dive into Image Processing for i.MX 6 Series Applications Processors
VPU:
Q&A: MX6 VPU H.264 Dual Stream Encode Limits
Thanks for the information. But I would still like to know how to enable support for VPU in kernel as this the task I received.
Thank you,
Mihaita
Thanks again for the info. i don't seem to find the CONFIG_MXC_VPU option in my kernel config or in my kernel tree. I don't have any mxc directory in my kernel tree. Do I need to install some package in order to have access to the video sources ?
Thank you,
Mihaita
what BSP are you using ?
One can find Linux Manual in BSP package, then
check VPU chapter.
~igor
