Tengo instalado el codewarrior 10.6 y cuando abro un proyecto no me deja agregar componentes de la libreria, me aprece en gris.
Solved! Go to Solution.
Whether you can create a new bareboard project in CodeWarrior v10.6 and enable “Processor Expert” option when creating it? Whether the components are available in the Components Library?
If yes, then the problem is probably concerned with the project, could you please attach an example project to help us reproduce the problem? Thanks!
Fiona Kuang
Technical Information & Commercial Support
Fiona Kuang
